LA534 grease zerks
Stmar
B2650HSDC
May 23, 2017
906
42
Buffalo, Wyoming
Does anybody know what size the grease zerks are on the LA534 FEL quick attach, specifically the ones on the lift that grease the pins that hold the bucket on. I want to replace the straight ones with 45 or 90 degree ones so I can use my LockNLube.
number two
B3030HSDC L2501HST
Mar 26, 2021
289
133
Northern Lower Michigan
Since the loaders are USA made,I would expect fractional sizing.
Smaller threads are 1/4 x 28NF(fine thread),while a little larger ones are 1/8" NPT(pipe thread).
The ones I've changed on my LA403 have been 1/4 x 28.
Good Luck!
Stmar
B2650HSDC
May 23, 2017
906
42
Buffalo, Wyoming
1/4 X 28 NF, hard to get to and tighten. Needed an 11/32 wrench which I do not have so I used a universal socket that grips anything. Also a challenge to get it tight but in the correct orientation.
3,032
Every Kubota owner will be faced with a Mix of SAE/Metric items. For zerks…go purchase a “kit” of SAE and a “kit” of Metric zerk-fittings and keep them in your toolbox. Sooner or later a zerk will seize or otherwise need replacement and you’ll be “equipped” to take care of it.
HF sells kits in both…so does NAPA, AMazon, etc.
Here’s a ”kit” which contains both SAE and Metric assortments:
number two
B3030HSDC L2501HST
Mar 26, 2021
289
133
1/4 - 28 UNF = M6.3 x .91
Thats close enough i would guess an M6 x 1.0 will start and screw in several threads deep before it binds.
Great math!
Several decades ago I screwed in a 1/4 x 28 grease fitting into a Toyota part and it sealed perfectly,or it did not leak .
No metric fittings available at the time.
Thank you again for your post!
