L6060HSTC and wood 17foot batwing
jdmcb
L6060
Aug 12, 2019
17
Burlington
Will a L6060 handle a woods 17 foot Batwing finish mower. It says 40 horse min but its turning 9 blades. Will only use on a field with shorted grass.
Thanks
SDT
multiple and various
Apr 15, 2018
3,256
1,042
SE, IN
Thanks
No chance unless you are play mowing.
That said: Who makes a 17' BW?
12', 15', and 20' BWs are readily available but I've never heard of a 17' BW.
SDT
OK, "finish mower."
Probably, if you cut regularly such that grass does not become too heavy.
SDT
jdmcb
L6060
Aug 12, 2019
17
Burlington
9204RD2 PTO-Driven 17’ Turf Batwing Mower.
Not sure
if the info is correct. I could be a 15 foot.
SidecarFlip
Banned
555
Irregardless, you don't have enough 'balls' for either.
BigG
Sep 14, 2018
1,951
770
West Central,FL
According to the Woods web page, https://www.woodsequipment.com/productDetails.aspx?id=332, the mower is 206 inches wide. That would make it 17.16 feet wide and cut 1 to 5 inches high. The page says it requires 40-80 hp at the pto. According to tractor data the L6060 has 53 hp at the pto.
So according to the information published the L6060 may not have enough "balls" but it should have enough ponies to mow.
Just saying the L6060 may not be a over sized like your two big tractors would be but he should be able to keep his grass cut.
