1 year old Kubota L6060 with cab. When temperature is below 25 degrees F turn key to start no glow plugs and then error code for CAN not working. History when this problem started glow plug indicator would never come on and sometimes it would start and sometimes CAN error. Under warranty they replaced the computer and now the glow plugs indicator on display will operate all the time except when CAN error displays on no start. Seems to be temperature related as it has happened only when the temperature falls below 25 degrees. When I get the error I apply heat with heat gun on back side area of the computer and in 2-3 minutes it will start. Today lifted seat up on no start applied heat to front of computer - no start then applied heat to area behind computer and it started. So it appears to be temperature related in the area behind main computer.
Any suggestions before I give the whole thing to the dealer and let them chase their tail
Of course now we have snow and cold I need it
Thanks
Thanks
