L3940hst hydraulic leaver doesn’t move left or can’t put in float mode anymore?
jack3940
KUBOTA L3940 HSTC
Nov 25, 2023
toronto
I was plowing snow for about an hour with everything working good and then the hydraulic control lever for the front plow locked up. I can still raise the plow up and down but I can’t put in float mode or angle the blade left anymore. It feels like the lever is stuck as it won’t let you move it. Any ideas before I go out and look at it tomorrow? Thank you
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,236
1,215
E.
first thing I would check is that the linkages are not iced up.
11,486
Any part of the spool valve or the linkage could be iced up.
Or something in the linkage has gotten loose or broken.
jack3940
KUBOTA L3940 HSTC
Nov 25, 2023
toronto
Ok thanks. The linkages should all be right underneath the hydraulic lever? It was super cold yesterday around -15 celcius and I’ve never plowed in that temperature before.
MapleLeafFarmer
Dec 2, 2019
1,236
1,215
E.
Ok thanks. Where would I be able to see the linkages, if I take off the rubber boot?
correct... in and around that whole area check for buildup of ice and snow, bent or disconnected linkages, etc....
11,486
This should be your linkage setup:
Your other issue could be that, you could have water in the detents.
They will freeze up and then cause the issues you explained.
That is a much more complicated issue to address.
Try heating up the valve area and see if the issue goes away.
Bee-Positive
BX1880, Cab, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
1,277
1,158
Amsterdam, NY
Just a wild a$$ guess and a potential quick fix. More than once I've had my lock lever wiggle halfway to lock which prevents the stick from fully moving. It usually prevents the boom from raising and lowering which you say is OK so maybe not.
