l3710 THE 3 POINT IS STUCK WILL NOT COME DOWN
aaonei
ky
The lever is very free ,seems that has no pressure.The rock shaft is stuck up and will not drop.The speed control is all the way out..help
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
78
Rocky Face, Georgia
I assume you have tried to adjust the speed control knob. Have you looked at the 3pt control to make sure everything is moving as it should?
6,403
Re: l3710 The 3 point is stuck and will not come down.
2 things come to mind, Roll pin on lever has fallen out or broken, (rare)
or the feed back linkage has become disconnected (more common).
5,214
1,897
In order of the most frequent to the least frequent:
drop speed control "off" (you've ruled that out).
position control feedback link came loose/off.
lift lever roll pin sheared (unlikely unless the lever is forced somehow)
position control valve problem
hydraulic cylinder problem.
