L355SS-stpped moving
David-in-OK
L355SS, brush hog, box blade
Aug 2, 2020
58
Oklahoma
I Just got it back from the shop. Started to pull out my flat bed from a muddy pasture with the bucket and it stopped moving. No forward or reverse and the 3 point wont move. It was a little low on hydraulic oil, i added couple gallons and still nothing. Ideas?
975
Take it back to the shop if that is what they fixed!
No other idea on that problem though.
4,856
It's possible that the pump has cavitated, if it's cold it could take some time, try cycling the three point several times while it's at an idle.
If you still don't get anything pull the filter and see if it's full of fluid.
David-in-OK
Aug 2, 2020
58
Oklahoma
It was something like that. My mechanic stopped out and messed with it and it moved normally. He said it was probably a clog. I think that it as more like you described that it cavitated. A week before, the oil sight glass blew out and I lost a lot of fluid. After permatexing the sight glass and added fluid I probably introduced air bubbles as I drove it a little when it was low on fluid.
4,856
Glad to hear you got it going again.
If she gives you more problems down the like pop back on and I'll give you more Places / Ideas to look at.
