L3400 turns over strong but will not start
Roques
Kubota L3400
Mar 14, 2021
Tractor was working fine in the field then suddenly died. Turns overs strong, but will not start. I have done some initial research and I have noticed there is no click when initially turning the key to start. I guess this is supposed to be the engagement of the fuel solenoid. Any advice? I have seen some suggest removing the solenoid to see if it starts without it. Others suggest testing it.
Not an experienced mechanic, but willing to try.
Roadworthy
L2501 HST
Aug 17, 2019
1,649
526
Benton City, WA
Try removing the fuel line at the fuel tank or fuel filter to see if you get a good steady flow of fuel. Sometimes there is a blockage inside the tank preventing fuel from exiting. It's also possible your fuel filter itself is blocking the flow. Once in awhile even new ones are defective. Always start with the basics. If there's no fuel to the solenoid there won't be any fuel past it either.
South 40
L1500DT, 750 Ford backhoe, 49 D4 Cat Repowered with 6.9L Diesel
Nov 12, 2012
168
53
Bloomsdale, Mo. USA
Hey Roadworthy,
Not sure how the fuel system is made on that model, but a diesel needs compression,timing and fuel to run.
So if it was running strong then died did it make any unusual noises when it died, or did it just stop running, if that is the case then you have a fuel system issue.
I just did a big write up on trouble shooting the fuel system, here:
https://www.orangetractortalks.com/forums/threads/injector-pump.57605/#post-548962
Follow that guide and you should find the problem in short order.
Cheers
Samantha
saxon
B1550, BX2230, G2160
Sep 29, 2011
50
Pelzer, SC
Seems like you really should hear the click sound when turning the key. The click sound is the solenoid pulling in to allow fuel flow.
JerryMT
Jun 17, 2017
528
156
The Palouse - North Idaho
Your tractor may have a two solenoid fuel shut off. Check to see if there are two wires going to the solenoid which is located on the injector pump (IP). One solenoid is the "pull in solenoid" which pulls the fuel valve open then eventually is de-powered. The other solenoid is the "hold solenoid" and it holds the fuel valve open until you shut off the key switch. Since you engine shut down while after it was running and you did not hear the solenoid click when you tried to re-start, I'd be suspicious of a loss of power to the fuel solenoid. Could be a loose wire, bad key switch, an interlock switch not closing, etc or a failure of the solenoid itself.
Little Jim
L3400DT W/LA463..
May 20, 2022
Houston Texas
Little Jim
L3400DT W/LA463..
May 20, 2022
Houston Texas
If you are familiar with a VOM check the voltage going to the stop solenoid. Ghe connection to the solenoid hoes bad through tough use. If you are not getting the click when you turn the key it is not getting fuel. If not the wiring and plug replace the stop solenoid. Been there did the run around replacement until I got lucky. Good luck
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,236
1,018
Williamstown Ontario Canada
