Update,
I now have about 100 hrs with the concrete weights, no cracks in the concrete, I torqued them to 30lbs, they did seem to loosen a bit after an hour or so of driving I retorqued and as some recommended I added loctite and locking washers.
What I would do different,
1. More bubble removal, 1 min per rim removing bubbles with a reciprocating saw banging in the rim is not enough.
2. More lug bolts, should have used 6 instead of 3,
3. Taken more time to tighten the wire more that connected the rebar to each other.
4. Embedded a design in the surface, just for looks
