L2900 Glow Plug sensor?
1Dragon
L2900
Nov 25, 2009
14
Sunny Central CA.
Hi All
Does anyone know if there is a temp sensor in the glow plug circuit on a L2900. For the last six months the glow indicator comes on every 2 or 3 minutes while running and stays lit for the usual 5 seconds as if it thinks the engine is ice cold. If only I had a wiring diagram!
Ken
Stubbyie
879
Midcontinent
Agreed wrt glow plug controller.
Get a parts schemat and find it behind dash.
On mine the controller finally failed and glow plug indicator stayed lit constantly. Side effect was the current draw constantly feeding glow plugs kept the battery pulled way down requiring boost to start each time.
After R&R controller the battery started behaving normally.
Apparently no damage to glow plugs.
Controller was about $70 two years ago. Look online for better deal.
Just for SAFETY disconnect battery neg term before fiddling with controller.
