L2650DT clutch adjust... 1mm Between Where ?
Battalion310
L2650DT
Dec 18, 2023
Calaveras
I've got the bell housing cover off of L2650DT so I can adjust the clutch.
The manual shows a pic where the measurement is 1mm on the left end of the adjusting bolt.
I don't see any way to get a feeler gauge inside the housing to check it.
A'm I missing something.
1,431
I think that adjustment is done when the tractor is split.
Post a picture of the manual and someone smarter should clarify what you can adjust
6,532
This is the adjustment only if you have a two stage clutch.
I do believe this only adjusts the PTO stage and not the travel stage.
