the bluing is from the heat treatment process, the journal has a lot of metal transferance, but , a machine shop should be able to regring it with no problem , I have done this many times, just have to get the bearing measurement for the machine shop, & when you get it back use plastiguage to check oil clearence , make sure you clean out the block oil gallies, there will be metal shavings all through it from the bearing failure
