L2501TSC 48 inch Box Blade or no?
PapaJ
L2501 HST
Apr 28, 2020
284
107
TX
Search did not yield enough info, so here is my question. The L2501 calls for a pretty small box blade. Anyone have the 48 inch TSC one and can speak to its quality? The reviews are all over the place, and youtube isn't much help. I mostly would be using this to work a 40 yard gravel driveway, but backing for dirt work is also on the list. I don't want bent attachment arms like I"m seeing if it is really a common thing with it.
1,418
I believe that bent three point arms are generally due to backing up with a ground engaging implement and hitting something fairly immovable with the implement.
So just push loose material while in reverse and don’t try to use too much speed or force in reverse. Tractors are designed to pull things forwards not so much to push in reverse.
chriscozi
BX23S 3rdFunction TerraKingBagger 4ftBoxBlade 5ftPlowBlade 3ptQuickHitch
Nov 26, 2020
Rutland VT
www.sugarwoodschool.org
Bought the 48" several years ago. Works well.
I NEVER back up with it on anything but very loose material.
MAKE SURE you get the Type 1 3pt. They sell a Type 0 3pt - which is what I got.
Luckily made an adaptor work.
And a hydraulic top link is the bees knees.
OntheRidge
Nov 1, 2020
328
382
48" seems way too small for a 2501, i ran a 72" on my 2501 with no issues. good Luck!
I found this video very helpful.
6,407
Who told you it could only handle a 48" box blade???
You can easily use a 60", you just can expect to move a mountain in one pass.
And you're highly unlikely to bend the three point arms, you would have to do something really of wall to have that happen.
Are you going to use it to maintain the drive or just build it?
Maintaining is better done with a Land plane than a box blade.
2,820
I concur with the above statements.
I have a 60" Homestead Pinnacle BB and the General Lee has no problem with it.
As a matter of fact, a 48" wouldn't even cover the tracks I don't think?
The Evil Twin
L2501, LA526,
Jul 19, 2022
2,823
2,844
No, a 48 wouldn't. I have a 60 on mine and it is only slightly wider than the tracks.
marrmanu
B2620 3pt chipper, box blade, post hole auger, custom 3pt chain box with hooks h
Jan 16, 2021
104
91
usa
Your profile lists a BX2680, which a 48" might be appropriate. As mentioned the L2501 should handle a wider blade.
PapaJ
L2501 HST
Apr 28, 2020
284
107
TX
The implement guide on the Kubota site says 52 inches max box blade. The driveway already exists, I will just be bringing out the rock a couple times a year. I figured I could go bigger, but always nice to hear from real world experience. I moved up from a BX 2360 and that thing didn't do much. I can at least move round bales of hay into the run in shelter now.
6,407
Like I said for maintaining I would use a land plane over a box blade hands down!
Grandad4
Apr 5, 2016
326
81
Greensboro, NC
Always thought those factory implement recommendations leaned to the conservative side. It may be that Kub is being extra cautious because of the comparatively low rated horsepower of the L2501. For comparison, my BX handled a standard sized 48" box blade with ease.
