L245 fuel gauge?
Shawnwright1
L245dt
Jun 27, 2013
Woodstock On
So I noticed a Picture referencing fuel gauge on side of fuel tank? Mine just has a small dark hose? Is it supposed to be clear? how is it meant to function....,, thanks
1,412
Yes it is supposed to be a clear tube. They often seem to be painted over or so dark you can't see the fuel.
When it is clear you will be able to see the fuel as it moves down the tube from usage. If you can't see fuel it is either really full or nearly empty - you kind of have to know which it is or look in the fuel cap to see if it is full.
There is a nipple at the top and the bottom of the tank, about a half inch to one inch from the top and the bottom. They are bent 90 degrees as they come out of the tank, top points down, bottom points up (go figure!). The nipples have a little bulge in them near the end.
The tube slips over that and is held on with these little wire rings. The rings are two or three turns (in a helix like screw threads) that clinches the tubing tight so it doesn't leak. I have no idea how they are supposed to be installed (professionally). I took two small screw drivers and pushed the ends toward each other so the hoops expanded enough to get over the bulge in the tubes. It was frustrating and time consuming so I assume there is a better way to do it. If you heat the tube up in warm water (blow it out before installing it) it will shrink (in length) and be a tighter lengthwise tube after it cools down.
All the parts are a few dollars (less than $5?) from the dealer. You can probably get the tubing from the hardware store. I guess you could use small wire ties to cinch it tight.
Time your fueling and you won't have to drain the tank to do this. But don't run completely out!
Kubotaman41291
Kubota B8200, 1995 Dodge RAM 1500 5.9l V8 4x4, 18 ft. flatbed trailer
May 13, 2011
22
Murfreesboro, TN
is it possible to install a aftermarket fuel gauge like the ones found on newer tractors that actualy have a sending unit?
GSDGUY
L245DT
Sep 7, 2009
Daleville,In
I have an l245 and noticed the same dark line on the side of the tank. I replaced it with fuel line from the local lawn mower shop and used Ty-raps to secure it. It's not under any pressure so it worked fine.
