My M7060 is an open station with a 4 speed transmission with high/low range. (8 speed)
The problem is that a bolt came out of the linkage that connects the high/low range shifter to the linkage to the transmission. There are 2 bolts on that connection, 1 is gone and the other is loose. It is stuck in low now and I can't shift to high range.
The location of the linkage, with the missing bolt, is down under the transmission shifter. I can see it from above but can't get to it from the top. I also can't get to it from underneath.
It's a simple fix but I can't get to it. What is the easiest way to get to that part?
Thanks
Thanks
