kubota M6060
WyoHomestead
Wyoming
Considering buying an M6060 with cab and heat/ac. Does anyone notice a considerable amount of hp reduction with running the ac? Would it be enough to keep you from pulling a 2 bottom plow or running haying equipment? Thanks!
SDT
multiple and various
Apr 15, 2018
3,256
1,042
SE, IN
The M6060 is rated at 56 PTO HP.
I would expect the AC to pull 3-5 HP at times.
Should have no problems with 2 bottom plow or appropriately sized hay equipment unless altitude is an issue.
SDT
WyoHomestead
Wyoming
SDT
We are in Wyoming at about 5-7k feet. Debating stepping up to the m7060 for the extra hp just in case.
Thunder chicken
M7060
Dec 29, 2019
295
120
Northern ontario
Something else to consider (at least in our province) tax rules means no sales tax above 60PTO hp. 7060 could be ‘cheaper’. :)
Brian H
MX5200HST, MTL RK5 Gr, Ford 850, King Kutter brush hog, rototiller, blade, disk.
Feb 8, 2019
44
Waupaca, WI
Unless you are pulling that plow through granite you should easily pull a 3 bottom plow with your ac on with that tractor.
