Kubota L4310 No Start
Vahunter
Kubota L4310HSTC; Woods Ground Mover LC102 FEL; EA Wicked 60 Grapple
Mar 15, 2021
19
Good Evening Gents.....I'll try to tap into the knowledge of you guys once again. Same tractor, new issue. I was bush hogging with no issues and went back in to my shop to refuel. When I tried to restart, I get an audible click but the engine won't turn over. With the help of my father in law we confirmed the battery, battery cables, starter/selonoid, and ignition were good with the multi meter. In my mind, this leaves me with two possibilities, a starter relay or limit switch (no idea on the location of these). Any ideas you folks have would be greatly appreciated. Thank you!
Vahunter
Mar 15, 2021
19
Thank you, but the PTO is disengaged. I've ordered a new PTO safety switch.
Hugo Habicht
G1900
Jun 24, 2024
957
1,360
Ireland
Is the audible click the starter solenoid? I.e., does the starter engage with the flywheel but does not turn? If yes it could be the starter contact closed by the solenoid of the starter brushes worn.
Bee-Positive
BX1880, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
484
483
Amsterdam, NY
Do a load test on the battery or switch it out with a known "good battery".
You can have good voltage but not enough amps on a bad battery.
