Kubota L2000
Mike S
Kubota L2000
May 28, 2014
Christiana,Tn.
does anyone know on a L2000 with a 4 speed pto, what gear should I use for bush hogging. I use high 1 for transmission but not sure about pto
8,734
Got a 4 speed in mine too :) 1 is 540, 2 is 750ish, 3rd is 960ish, and 4th is 1100ish ;) i had searched on this site and found it. Can't remember the exact that they said it was. Most attachments would be powered in 1st on the pto :)
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
Everything pto wise runs at the standard 540rpm. The other 3 gears is if you want to run something like a pto generator and don't want to crank your throttle wide open and burn up fuel.
