OP please replace “oil” with “diesel fuel oil” if @DustyRusty confuses you by using “oil”. He does not mean engine oil.loosen the line at the injector a half turn. Crank till oil comes out. Do each line separately. Then try to start. If that doesn't start the tractor, you have other problems such as the shut-off valve being stuck closed.
I would also suggest to set the throttle above midpoint to speed up the fuel movement.
