Couple of problems with the b2320 just started for some reason.
The rear pto tries to engage by its self. Not all the way and just a slight noise as if grinding. I have a 52 inch tiller attached and it does it when the tiller is on the ground. If I raised the tiller just a little it stops the noise. It's the pto ok as I was standing in the back when it started one time and the pto/tiller shaft turned a little. I inspected the lever linkage and noticed the hairpin was missing. Replaced it and sprayed some wd40 along the lever to where it attaches to the shaft. Noised stopped for a few days and now returned. Belly mower is attached to tractor and the rear pto never tries to engage when mower is in use. Talked to local service folks and they have never heard of a problem like this. I have the schematic for placing lever and bushing(s) but not sure that will fix it and not sure if the lever or rod is bent a little to cause the problem.
Other problem is when using the tiller , Ansung 52 inch , is when I get to the end of the row and raise the 3pt hitch the tiller digs a hole before tiller is lifted off the ground. Ground is soft as the I have used that portion of the property for a garden over 6 years.
thanks
junior
thanks
junior
