Kubota B20 with BT750 backhoe valve question
crazzy450z
Acton, Ontario, Canada
Good day everyone..
I'm hoping to get some help for the hydraulics on my BT750 backhoe.
This unit comes with a option for auto boom return that frequently acts up.. This auto return function is run off a few sensors and a set of solenoids attached to the hydraulic valve body. Well one of the solenoids packed in in the other day.. Actually the top blew off of it.. I am looking to replace this valve body with a manual actuated valve and completely remove the auto return as i don't use it, and some of the other sensors are not working on it.. From what i can tell the valve stack is a Husco 5000 series. So does anyone know if i can take a non kubota valve and inset it into my current stack?? I'm looking to use this valve.. Since i cant post links yet here is the Ebay item number 201956263622.
I do have a few pictures i can post if it will help.. I figured i would get the conversation started, as i do not know what information may be required to determine if this will work or not.
Thanks in advance.
Kevin
Cloud
Kubota B20
Aug 5, 2014
22
Dalton Gardens, Idaho
Good day everyone..
Thanks in advance.
Kevin
I have a similar problem and was also thinking I would add a manual valve but haven’t had any luck locating one. Did the EBay valve work? Thanks
crazzy450z
I ordered a new valve section to replace the old electric one from ebay.
HUSCO N5002-A1 HYDRAULIC DIRECTIONAL SPOOL VALVE SECTION 352056 4820-01-313-4697
It bolted right in place. I did end up having to find a couple Japanese to US hydraulic thread adapters.
I think all I did was remove all the electrical components.
Cloud
Kubota B20
Aug 5, 2014
22
Thank you so much! I’ll get right on it.
Ken speirs
Kubota B20/BT750B
Sep 30, 2026
40
I am going to bypass the auto return too. Any information would be very helpful. Thanks
I too would like to bypass the auto return on mine! I see your info on the HUSCO N5002-A1 HYDRAULIC DIRECTIONAL SPOOL VALVE SECTION 352056 4820-01-313-4697. Has anyone else purchased this with success? Not to doubt, I'm such a novice at these things, if anyone has more info it would help. thank you.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
4,077
2,514
WestTn/NoMs
The N5002-A1 is a plain vanilla section; they appear on eBay from time to time. Are you sure it's the correct one? It's not prepared for port reliefs if needed; my BT900 has them on the swing, but I don't see them offhand on the BT750. Also, there is a handedness, the spool connection can come out the top or bottom depending on model number, just be aware.
Do you have a plan for the linkage from the joystick to the valve?
Ken speirs
Kubota B20/BT750B
Sep 30, 2026
40
No, I haven Much of a clue. New to tractors and mechanics. Just starting at getting educated. Thank you for your knowledge.
