Kubota 2005 RTV 900 hydraulic lines
cwb337
RTV 900
Jan 20, 2026
Can anyone give me (or tell me where to find) the specs or the part number for they hydraulic lines that run from the front (plow hook up) to the remote hookup in the rear? (The same place the dump bed plugs into).
3,186
You can see illustrated parts lists and diagrams here
There are a lot of different RTV900s listed so you may need to get the complete model number off the sticker on your vehicle.
whitetiger
Nov 20, 2011
3,839
2,232
Kansas City, KS
Do you have to unplug the bed tilt cylinder to plug in the hoses to the blade?
Does your bladehave only a raise/lower function, or does it also have a hydraulic angle adjustment?
cwb337
RTV 900
Jan 20, 2026
Yes, you do have to unplug the dump.bed to run the power angle blade. The up down works on an electric pump.
whitetiger
Nov 20, 2011
3,839
2,232
Kansas City, KS
You will not find anything with the blade in the RTV 900 parts, as the blade will have its own model number.
cwb337
RTV 900
Jan 20, 2026
That crossed my mind. But the manner in which these lines are installed matches everything else from the factory. At the very least, this would have to be a dealer-installed option. These lines go from the rear remotes (the same ones the dump bed uses) and are controlled by the same lever /valve that works the dump bed.
cwb337
RTV 900
Jan 20, 2026
I ended up getting some hydraulic line from a local guy that makes hoses. I appreciate everyones help.
