I have a KUBOTA B1750 HST 4WD. Can I fit a LA211 Loader
X-Man
B1750 HSTD
Jan 29, 2024
22
AUstralia
I have been searching everywhere. A person had posted a picture that it was possible, however, I am not sure if thee is any retro-fitting involved the poste was more that 4 years old.
4,897
It'll take some time, but look at the 'parts pages' of both LA211 loader and the LA300. 300 was for the B1750, la211 for the BX1800/1830 according to tractordata. Check part numbers for mounting plates,frames ,etc. to see IF same parts were used on them.
SDT
multiple and various
Apr 15, 2018
3,250
1,041
SE, IN
Don't see how that could be done without extensive modifications.
That said, certainly possible with enough money and/or time.
jaxs
B1750HST
Jun 22, 2023
733
522
Kubota loaders and what they fit is confusing at best. It is important to realize a single loader will always fit several brands and models ,,,,,BUT,,,,,,,,,each brand and model requires a specific mounting kit. Kubota doesn't go out of their way to let owners know this and list each loader with mounting kits for various tractors. Personally I believe it's a ploy to make it hard to buy used loaders so that folks buy new from dealer. I can tell you for certain a Bush Hog 1840QT fits your B1750 HST. I suggest you look at Bush Hog brand or other brand that accomidates customers with spreadsheet listings of mounting kits. To get the feel for what I'm saying go to German Bliss to look at 1840QT loader and numerus kits for various tractors.
6,347
You would have to do some extensive rework to make it fit
The LA211 has no subframe
Where the LA300 does.
And you need this or you'll break your tractor in half.
X-Man
B1750 HSTD
Jan 29, 2024
22
AUstralia
Thank you very much for all your info. It is now clear to me, that this is a hard ask. I am in Australia and I cannot find a Bush hog dealer. But I will keep looking:)
X-Man
B1750 HSTD
Jan 29, 2024
22
AUstralia
Thank you for your info. very informative. I will keep looking
jaxs
B1750HST
Jun 22, 2023
733
522
I to am interested in adapting loaders to B1750 and it sounds like you have experience/expertise/insight for getting it done.
What tips do you have for making B1750 compatible with LA211? Are you saying that LA211 can't satisfactorily operate from crankshaft or pto driven hydraulics and if tractor hydraulics don't match it's a no go? How might one accomplish necessary mounting points? Other than larger and/or higher load rated tires ,what else can be done to accommodate additional weight of loader?
X-Man
B1750 HSTD
Jan 29, 2024
22
AUstralia
Right, I may be biting off more than I can chew. o_O
jaxs
B1750HST
Jun 22, 2023
733
522
Thank you so much. That's the kind of information I need,it removes unknowns I've grappled with while trying to match my B1750 to loaders such as LA211.
X-Man
B1750 HSTD
Jan 29, 2024
22
AUstralia
Thank you for the research
6,347
This Thread was riddled with a spammers input, his input was just BS.
