O Orange man hero Active member Equipment LX2610HSD Mar 12, 2021 343 42 28 Wasilla, Alaska Jun 22, 2021 #1 Engine oils always specify hot change. Have not seen anything in KUB world on that? Getting ready to do LX2610 50 hr. Hydro fluid FILTER change.
N number two Active member Equipment B3030HSDC L2501HST Mar 26, 2021 289 133 43 Northern Lower Michigan Jun 22, 2021 #2 I warm up my hydraulic fluid before draining. I would imagine most any fluid would drain better warm. As to the importance,opinions will surely vary. Good Luck!
Roadworthy Well-known member Lifetime Member Equipment L2501 HST Aug 17, 2019 1,649 525 113 Benton City, WA Jun 22, 2021 #3 The hydraulic oil should be thinner and drain better when warm. That is the reason for changing engine oil when warm.
Elliott in GA Well-known member Equipment LX 2610SU w/535,LP RCR1860,FDR1660,SGC0554,FSP500, DD BBX60005 Mar 10, 2021 629 609 93 North Georgia Jun 22, 2021 #4 Since you will not be draining and changing the oil, cooler more viscous oil would make less of a mess/loss. Reactions: 1 user
T Tire Biter Active member Equipment B 2601 434 loader MMM, bunch of tractor stuff . Ford 4600 Jul 10, 2012 232 80 28 S.E. TN Jun 22, 2021 #5 Well seein as how you don’t need to dump the fluid, why burn yer hands changing filters? Reactions: 2 users
O Orange man hero Active member Equipment LX2610HSD Mar 12, 2021 343 42 28 Wasilla, Alaska Jun 22, 2021 #6 Elliott in GA said: Since you will not be draining and changing the oil, cooler more viscous oil would make less of a mess/loss. Click to expand... Yes, that is what I thought!!!
