Hey there, new to this site- I've enjoyed reading everything so far.
Have a new to me L345 with a loader. I have a hydraulic leak around the shaft of the hydraulic pump (located at the front of the tractor) and decreased power to the loader only- PTO is strong. I was able to find a rebuild kit with replacement seals. I think I will try this before buying a new pump.
I would like to do a pressure test on the system before and after this fix, any idea of the correct pressure specs on an L1700 loader. Also what kind of pressure gauge should I use?
Looking for any advise on rebuilding this thing. Do the bolts on the pump need to be torqued or any cautions when replacing the shaft seal?
Thanks for any advise.
Stan
Stan
