Hyd Filter
Noah
L3800 HST
Jun 13, 2015
Porter Maine
My other issue with my filter change on my L3800 HST was the right side hydraulic filter, the one with magnet in it. As soon as I loosened it, the fluid poured out, I waited for it to slow for like 30 seconds , then I realized it wasn't going to. So I filled the new filter with fluid, screwed off the old one quickly, screwed on the new one quickly. I figured I lost 1 1/2 gallons of the transmission fluid.
So how do other change this without loosing so much fluid ?
jimadd
29
SC
I just posted the same question about a bx's hyd. filter. I had a JD 110tlb do the same exact thing you just had happen to you. I sat there and watched as all the oil poured out of the drive......almost 4 gallon to be exact while trying to get the new filter on. Had I known then what I know now, I would have worn scuba gear to change it. And at 75.00 for 5 gallon, it was a lesson well learned.
In your case, I would think that if you are past the break in piriod, that the filter only needs to be changed when changing the hyd, fluid. Thats the only wasy I could think this would work without the oil bath part.....:confused:
Shadow
190
Somewhere
That's "normal". It sucks, but that's how it is. Try changing them on the bigger M series, usually lose about 3-4 gallons, if you're fast
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
I changed my fluid and filters at the same time, 22 gallons @$202.80 per 5 gal bucket.
So my M9000 takes about $900 in fluid and the last filters I got were $110 so call it a 1K tranny service. And you BX guys think you've got it bad.
8,666
Out of curiosity, what did you put in it, that it cost so much :confused:
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,801
2,192
Near Lancaster, PA, USA
When I changed the filter on my L3200, I used the vacuum cleaner method. Spillage was almost nothing.
Bulldog
Mar 30, 2010
5,434
76
Rocky Face, Georgia
Amsoil, but those are list prices which are closer to what I paid when the oil was changed. I didn't want to break it down to the penny, just a general figure.
Now that I have learned a few tricks I get a better deal. I have never figured it so this even surprises me, now 22 gallons cost about $500. So in real numbers it's not much higher than SUDT2.
chim
Jan 19, 2013
2,801
2,192
Please explain. Already bought the scuba gear, so maybe I can sell it...?:D
A trick I read about either here or another board. A shop vac on the fill hole keeps the oil from flowing out of the filter connection. Worked great.
