Does anyone have the part number for the front loader control valve for a B2920? Tractor was purchased in 2012 if that helps. Loader is a LA364
YW544-00102 - in stock at Messicks for a biscuit more than $1100.Does anyone have the part number for the front loader control valve for a B2920? Tractor was purchased in 2012 if that helps. Loader is a LA364
It appears to be a 2 spool monoblock valve. About the only thing you can service on them is the relief cartridge, spool return components, and the end seals on the spools. If the spools are worn its replacement time. What problems are you having?Thank you! Do you happen to know if they're rebuildable?
I would suspect the Rube Goldberg joystick linkages. The leak is a spool seal,.I am having an issue with the dump and curl function on the front bucket. I can get it to function, but only with careful manipulation of the lever. It also drips a little bit of hydraulic fluid from the bucket spool. I haven't been able to remove it yet because i've been using it, and it's raining here today. Very low hours on the machine, and I'm the original owner and only operator.
