Hi all. I'm new to Kubota. Recently got a bx2200, but it is acting up now after a few months stand still. I'm hoping someone here can help
So this is what happens: Top fuse blows as soon as I turn the key to 1'st position. Fuelpump still runs, and glow plugs work, and I can start it, but only as long as I have the key fully turned into start position. As soon as I let go of key and it returns to run, it cuts off. Also cuts off if I ease it back to glow position.
Don't know what the top fuse do, but I guess it's related. I'm not used to working on Kubota, so it's all a bit new to me.
I have made sure there is a good battery, and the battery is solidly connected, also on ground point and starter.
I don't see any wires rubbing on ground or things like that.
I have wiggled wires and connectors.
I can not hear anything from the solenoid on the pump, when I turn key to run position, but hr. meter and feed pump runs.
I have checked and lubed connections to ign. switch and solenoid.
Under seat, I have two wires looped together. I'm guessing a seat switch bypass. No change if connected or not.
Please, any advise would be greatly appreciated.
Thanks
Thanks
