Help Me Buy My First Kubota This Week
sodak
53
Sioux Falls
Hello future family!
This spring I bought 13 acres, and have been thinking for a long time about buying a tractor. I have it narrowed down to a used Kubota, but am having a hard time figuring out which model to get. I demo'd a B2710 with a 72" belly mower (which did a great job), and it seems to be about the right size for what I want to do with it, but it had almost 2000 hours, was kind of beat up, and I have read to "always buy more tractor than you think you need."
-I would like a 72" mower because most of the property is grass or pasture. I have a 60" Zero Turn that is old and the amount of maintenance required makes me think it should probably be sold or retired in the next few years. I do have a number of trees, so it makes me think I should go with a model that can handle the belly mower, but I do also have a 60" bush hog and might not be against buying a finish mower for it instead.
-A loader is necessary for cleaning out a chicken coop, moving compost, piles of snow, etc.
-It needs to be able to run a tiller - I'm thinking of an acre or two garden plot, a hops yard, and possibly a future orchard. I do have a few large dirt piles from a pond the previous owners dug, but that is the heaviest I might need a loader for.
My ideal price point is "around $15k" but I do have some flexibility. With that in mind, I am seeing B2710's in that price range, every once in a while a B2910. Other models that look good but I do not understand all of the differences in are the B3030, B2650, and B7800. I suppose I could go with a BX Model, but they seem a lot smaller and feel less like a tractor and more like a lawn mower.
It seems like the tractors out there have maybe 1 attachment, sometimes 2, of the 3 that I need. I'm guessing tillers are the easiest / least expensive to find, but I don't know how niche or expensive the belly mowers and loaders are.
I'm pre-approved for a $15k loan and could probably get more, or buy one of the attachments separate. I know the dealers have a heck of a deal with the 0% financing, but I'd rather pay a little less for a comparable, albeit older, tractor at 4%, than drop $20-30k on my first tractor.
TL;DR: Want to mow 72" at a time, run a tiller, and have a decent loader, for $13-17k.
B2710, B2910, B3030, B2650, B7800, or did I overlook a different B or L?
How many hours are too many hours?
Thanks!
millsrv
L2501 HST, LA525, BH77, Gannon Rollover Scraper, Titan Skid Steer Attach Forks
Nov 20, 2015
69
Placerville, CA
There may be a couple of things to consider with your used vs new scenario.
There are substantial rebates at the dealer for new equipment, plus the zero precent financing.
I purchased a 2015 L2501 agricultural lease return (treated as new by Kubota) with 26 hours on the clock. This was the bare tractor and the price was 13k. Adding the new LA525 FEL added $4150, total $17150. I received a $1250 November Tractor Rebate and a $750 November Implement Rebate from Kubota. Total cost for tractor minus sales tax :mad: was $15150. I negotiated a 50 hour service and a shop manual into the deal. The tractor has a full factory warranty and qualified for zero precent financing.
15k borrowed at 4% interest for 60 months = 276.25 a month.
15k borrowed at 0% interest for 60 months = 250.00 a month.
Difference =$26.25 x 60 = $1575 (in your pocket for implements)
I don't know if AG returns are available in your area or what the current Kubota rebates are, but this is something you might want to consider.:)
Billdog350
Kubota L3710 HST,L2230A QT,forks,Takeuchi TB125, 60" Luck Now pto Snowblower
Jan 6, 2014
468
10
East Hampton, CT
X2 to take a look at L's as well. Just make sure you don't end up with anything with DPF....lots of the new stuff has the emissions requirements for Tier IV and its GARBAGE.
Also many of the B models you're looking at are HST, if you want a belly mower you'll need HST for the L as well.
The B2910 and B2710 are great machines (as well as the B7800) but the extra 3 point lifting and loader capacity on the L shouldn't be overlooked. The only consideration will be which tires to get as well. Ag tires don't mow lawns well....turf are the best and R4 are decent if you don't have sharp turns or soft lawn....
Benhameen
Jan 27, 2013
691
115
Southern IL.
I had a similar problem when I went to buy mine. I was set on buying used until I figured up that I would be spending the same amount with the interest or lack there of. Bought a new L3800 and haven't looked back, love it!
Also, you might consider a finish mower for the back instead of the mid mount mower. I use one for my yard and some of my property and they work great.
Good luck with whatever you decide...
Oh and I leave my FEL off until I need it, makes it much more comfortable and easier to maneuver without it. 5 minutes tops to take it on or off.
sodak
53
Sioux Falls
Thank you both for the response.
Would an L series be too heavy for regular mowing?
How do I know if a tractor is DPF?
Reading a lot of threads on position control vs 1/4 inch, it seems that position control may be worth a little extra $. Also wondering if +3HP is worth the extra $...
I have a bead on three options currently
1. B3030HSD, under 400 hours with a loader, for less than $13k. Industrial tires. 2007.
2. B2710HSD, under 800 hours with a loader and 72" MMM for $13k. With Turf tires. Unclear to me if it has position control. 2002.
3. B7800, under 800 hours with a loader and 72" MMM for under $13k. Industrial tires, no position control or extra bells and whistles. 2007.
Thanks again for the help!
Benhameen
Jan 27, 2013
691
115
Southern IL.
My yard is nothing fancy but I don't have any trouble with the weight, R4 tires.
Not sure about the DPF on the newer models but my does not have it.
Again I do not any experience with the position control vs 1/4", on my L3800 I put the 3pt control all the way down into "float" and it glides across my yard just fine.
I'm sure someone in here with more experience with the B series can give you the answer you are looking for.
Good luck and post back what you end up with. As most would say we all like pics!!
bearskinner
Sep 1, 2014
926
241
N. Idaho
Have to agree with some of the comments so far. I looked at new VS used, ended up with a new K with a few extras, all at Zero interest. We have acerage, but only about 2 acres of lawn to mow, and purchased a big ride on mower as a stand alone, so I didn't have to deal with driving the tractor around the trees, and low branches, and removing the mower to get off in the weeds. The almost new ride on mower was way cheaper that the MMM for the Kubota. I also purchased the K with a backhoe, which I use as much as I use the FEL.
Fastdonzi
New Grand L3560
Dec 4, 2015
64
East Tn
I bought a New L3560 with an 805 Loader ( a $26,000 combo) I traded my old MF230 (4K) and got the Kubota for about 21K , my payment with the Kubota insurance ($1800 for 6 yrs) is only $320. It may not be the best deal out there but I was happy with it...
sodak
53
Sioux Falls
I went with the B3030, will pick it up in a few days. Couldn't turn it down for the price and # of hours.
Do you recommend I go with the dealer suggestion of adding Rim Guard to the rear tires for $250? Not sure how much weight it adds, or if I should worry about it with the industrial tires + mowing this spring, post snow melt? Guessing I could probably get it later if need be?
Ike
Kubota L 3301, Farmall Cub. JD B. Ferguson TE 20
Jul 18, 2015
324
Mich
I you have a loader get the rim guard you won't be sorry
RonBoyBX25D
B2650, LP Grapple, Bro-Tek spacers, QH, Box Blade, Landscape Rake, RB, and 1560G
Aug 1, 2015
477
Minneapolis, MN
Definitely go with the Rim Guard, I was told to wait with new to let the beads seat. Not sure if it is really necessary or not, but makes a huge difference with the loader and any side hills.
