Q Q tip New member Equipment BX25D Feb 1, 2020 18 0 1 Ct Jun 22, 2022 #1 not wearing my glasses i put a new battery in my bx but has the pos and neg backwards had some sparks hooked the battery up correctly but everything is dead no lights nothing is there a fuse i blew ? thanks
Pawnee Well-known member Equipment L2501 Jul 1, 2021 351 306 63 Ontario Canada Jun 22, 2022 #2 If you're lucky, the 50A main fuse blew. You should get the manual on kubotabooks. Reactions: 1 users
Mark_BX25D Well-known member Equipment Bx25D Jul 19, 2020 1,754 1,278 113 Virginia Jun 22, 2022 #3 Pawnee said: If you're lucky, the 50A main fuse blew. Click to expand... Yep, if he's lucky. Pawnee said: You should get the manual on kubotabooks. Click to expand... Agreed. But in the meantime..... Reactions: 2 users
Mark_BX25D Well-known member Equipment Bx25D Jul 19, 2020 1,754 1,278 113 Virginia Jun 23, 2022 #4 BTW, kubotabooks.com now has the manual for the BX25D.
OrangeKrush Well-known member Equipment BX2680, LA344 with Piranha tooth bar, LP PF 1242, LP Rear Blade, KK 60" BB Nov 15, 2020 1,047 515 113 Indy Jun 24, 2022 #5 Any luck with it?
D DustyRusty Well-known member Equipment 2020 BX23S, BX2822 Snowblower, Curtis Deluxe Cab, Nov 8, 2015 6,237 4,816 113 North East CT Jun 24, 2022 #6 Most likely also took out the diodes in the alternator. Reactions: 1 user
Mark_BX25D Well-known member Equipment Bx25D Jul 19, 2020 1,754 1,278 113 Virginia Jun 24, 2022 #7 DustyRusty said: Most likely also took out the diodes in the alternator. Click to expand... That's a strong possibility.
