Gearbox on RCK60-24B
Richard Skelton
RCK60-24B Kubota Mower Deck
Oct 11, 2021
Oxford, GA
I purchased a gearbox and got it installed, and the blades are turning backwards from what it has been doing for years. Are blades available for turning in either direction?
SDT
multiple and various
Apr 15, 2018
3,250
1,041
SE, IN
No.
You have the wrong gearbox.
SDT
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
2,805
1,522
WestTn/NoMs
There's one tractor, gray market probably, that has reverse PTO direction. Seems like there was somebody last year trying to reverse his. You must have gotten his gearbox :confused: .
Tire Biter
B 2601 434 loader MMM, bunch of tractor stuff . Ford 4600
Jul 10, 2012
237
87
S.E. TN
Just curious how you got ahold of a gearbox that turns reverse direction.....
im not even sure gray market tractors even had mid PTOs.
even if you found reverse blades, the deck wouldn’t discharge correctly among other problems.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
2,805
1,522
WestTn/NoMs
Yeah, I think you're right.
BruceP
G5200H
Aug 7, 2016
851
368
Richmond, Vermont, USA
I believe gearbox direction may be related to how it is driven.
for example. the mowdeck on my G5200 is driven by shaft from the front of the machine (from rear of engine) Perhaps, the mowdeck in this discussion is driven from the rear of the machine?
xrocketengineer
Nov 14, 2020
749
646
Merritt Island, Florida
I would suggest to read this thread:
Then make sure that the belt is routed properly and that you have the right gear box for that deck. Even a different suffix on the deck model number can make the difference on the rotation direction on the gray market units.
