Fixing ZD326 Jack and Removing Left Fuel Tank
Mr Haney
L3710, ZD326S
May 23, 2022
309
81
FL
Listen, my children, and I will tell you how to fix the infernal built-in jack on your Kubota ZD326.
The jack was one of the main reasons I wanted a Kubota. I figured it would make blade changes much easier. Then I bought a used Kubota with a jack that was nearly frozen.
No problem. I would just grease it later.
Today I finally got around to taking it apart, and I found out why it was frozen. When Kubota designed this thing, they included a generous serving of dumbass. I have to wonder if the engineer behind it is a descendant of Mr. Kubota himself. "What are we going to do with little Hiroshi? He failed out of Benihana school again!" "We call dad and get him a job at the company. Something unimportant."
To begin with, you take the jack off while the mower's deck is down. The is a little roll pin at the handle end, and you pound it out. At the other end, there is a thick pin that goes through the jack assembly, and incredibly, it is held in with a cotter pin. Pull the cotter pin, and the left end of the jack will be free.
I am replacing the cotter pin with a clevis pin. I don't know why Kubota didn't use a clevis pin. The jack is designed in a way that makes it highly likely it will have to be taken apart and serviced during the mower's life. A clevis pin comes right out, and you know what a pain big cotter pins are.
The jack handle is held on with a screw and nut. Pretty obvious.
The jack has three main parts: a dust shield that doesn't work, a screw that corrodes, and a nut that fills up with dirt. The shield is plastic, and for some reason it's held on with an internal retaining ring. The ring goes around the screw, like a ring on a piston. You pull, and the shield comes off. Putting the shield back on using the ring is not much fun, but it can be done.
The screw is plated with something that looks like cadmium, except where it wears against other parts without the much-needed bearing that Kubota didn't put in the design. That part is bare because friction removes the plating in a hurry. The bare area gets rusty, increasing the diameter and making the fit tight so the screw binds.
The dust shield does an excellent job of capturing dust and transferring it to the screw and nut. Once this occurs, it fills the threads and combines with your lubricant to form a coarse lapping compound that doubles as a thread locker.
Maybe Kubota designed this jack for impeccable Japanese lawns which are completely free of grit and sand because they are maintained by Japanese gardeners, but my American lawn, like many others, is full of bare spots, so this jack does not work well as designed. Sooner or later, it will lock up, necessitating the use of a floor jack or some other means of lifting the deck.
I disassembled the jack. I took the screw to the pedestal buffer and wire-wheeled most of the rust off. Then I went to a utility sink to clean the grit off the screw.
I used an amazing cleaning product: Aveeno Baby Daily Moisture Wash and Shampoo. This stuff is supposed to clean babies without drying their skin. My wife bought it for our son early this year, and in a short time, his skin felt like leather. It is possibly the harshest soap I have ever seen. It's like brake cleaner with a baby-fresh scent. It defats everything it touches.
We got different soap for the baby, but I kept the Aveeno for removing black grease from myself after I work on machinery. It's faster than mechanic's hand cleaner.
The Aveeno and a brush ripped the grease and dirt off the screw, and I used my wife's toothbrush on the nut. I haven't told her yet. It was a new one she hadn't opened, so I have time to replace it.
I greased the nut and screw with Super Lube and put the jack back together. I felt I had to do something to improve it, because I knew grit would start filling it up a week from today during the next mow.
I got a caulking gun and filled the open (left) end of the nut with silicone. I am letting it cure now. Once it cures, there will be a big rubbery plug blocking the once-open end of the jack. I may be wrong, but it looks like there is ample room for the plug. If not, I'll yank it out and try something else. It should greatly reduce dirt intrusion, and if it does, the jack will actually be useful.
I am also working on the left fuel tank. The mower stalls when I use it. The problem isn't the filters, pump, cap vent, or fuel lines, so I am cleaning the tank.
A helpful person said the tank was easy to take off and supplied information about removing the fender it sits under. Unfortunately, this information is not quite right.
You don't have to remove the fender to get the tank off, and that's a good thing, because you have to remove the step (floorboard) in order to get the fender off. The fender has a long tab that runs under the step. You have to remove a screw from the tab and pull the tab out from under the step. To do this, you have to get the step out of the way.
Fortunately, the fender can stay where it is. If you remove all the screws holding it on, you can lift it enough to get the tank out.
Unfortunately, the fuel hoses that have to be removed from the tank have death grips on the tank's nipples, and so far, I have not managed to get them loose. It is also necessary to remove several screws and take out the fuel sender, unless there is some way to detach the sender's wiring upstream. I have not found anything like that. I should cut the wires and make them detachable using plugs and receptacles.
In summary, the jack is a pretty good product for people with perfect lawns, but for the rest of us, it requires modification or frequent cleaning and lubrication.
5,693
re: fuel line removal....
I use a 'bent, forked screwdriver' used to remove plastic 'trim' plugs. You get behind the hose and PUSH it off the spigot. Some lefty-righty action helps.
Mr Haney
L3710, ZD326S
May 23, 2022
309
81
FL
Thanks for the help. I am looking for that tool online.
Speaking of push rivets, Kubota charges over two dollars each, and I need quite a few. That's a lot of money for a bunch of parts that probably cost 5 cents each to make and ship to dealers. I'm trying to find out if they can be reused.
I'm also trying to get the scalp-wheel pins and shafts loose. I need to lower the scalp wheels because I am banging up the deck skirt. I managed to get one pin loose with vise grips, but the other one has gone nowhere so far.
I have a couple of air hammers, but oddly, I never ordered hammer bits. Just pointy ones. I have a flat bit on the way. I am hoping the air hammer will get the remaining pin out.
The shafts themselves seem like they are really stuck. I may have to heat the parts they fit in in order to get them to move, and then I would have to repaint part of the deck.
Mr Haney
L3710, ZD326S
May 23, 2022
309
81
FL
I have good news about push rivets, also called trim clips, and I am here to post it for others.
Of course, being the person I am, I had an unused trim tool assortment in my shop, so I got it out and popped a rivet out of the mower's deck gearbox lid. The rivet came out just fine.
The hole fits a 15/64" drill, so Ebay rivets advertised for 1/4" holes should be just fine. My guess is that these are 6mm holes, because the rivets are very tight, and some refuse to come out with a trim tool.
I found out the standard material for these rivets is nylon, which is a commodity as far as I know, so I have no reason to think Kubota rivets are better than Ebay rivets.
I have to apologize to dealers for suggesting their cost for these $2.60 rivets (before shipping) was 5 cents. It is actually MUCH LESS. You can get 100 of these things for $2.99, including shipping, so Kubota has to be getting these for less than a penny each, and I would guess the dealers aren't paying much more.
I'll be paying $2.99, so that is a little better than $68.11 (for 21 rivets) from Coleman's.
Obviously, the dealer price for 100 rivets would be $260 before tax and shipping.
5,693
Some just HAVE to have OEM parts for their rides, so THEY are willing to pay the 'price'. I prefer to shop around and get a deal. I have an $$$$ gas stovetop, 25 years old and the rubber 'feet' for the grilles are gone. OEM replacements are $6.45 EACH, need 8, about the size of the eraser on a pencil. TEMU (which many here hate...) have dozens of 'possibles'. Got a bag of 100 for 4 or 5$. They fit perfect, do the job and cost a LOT less.
3,448
mikester
M59 TLB
Oct 21, 2017
3,879
2,523
www.divergentstuff.ca
I got these push pins from amazone for my motorcycle. You can find something that matches yours online pretty cheap.
CGMKCM
RVT-1100C, ZD323, L4760
Jan 26, 2021
453
240
Randolph county N.C.
JMO, 1800hrs on my ZD 323 and the jack works perfectly. I suspect your mower was left out in the weather and didn't get much cleaning. I use a leaf blower to clean my jack and mower deck after every use. I do not use any lube on the jack screw because it attracts and holds dirt.
whitetiger
Nov 20, 2011
3,186
1,604
Kansas City, KS
Go back and reread the removal instructions. It takes me 10 minutes to remove the operator's platform and fender, making removing the hoses and wiring to the sender a walk in the park. I remove nearly a dozen tanks and clean them every season. :)
Mr Haney
L3710, ZD326S
May 23, 2022
309
81
FL
I appreciate the reply, but I am wondering if you have a newer mower with a different step or fender.
Here are the only instructions I can find in the manual:
Seat Assembly and Fender
1. Raise the seat and disconnect the wiring connector for safety
switch.
2. Remove the seat assembly (1) with seat base (2).
3. Remove the fender (LH) (3).
4. Disconnect the wiring connectors for gauges and remove the
fender (RH) (4).
I don't know if this manual goes with my mower's year.
"Remove the fender" is a little terse. It's like "Remove and rebuild the engine." It comes with a photo of a mower with no indication of the locations of the screws that hold the step on.
My mower's fender definitely has a long tab that goes under the step, and the tab has a screw that goes to a nut under the step. I removed the screw, and it was not possible to remove the fender without taking out all the other step screws. I haven't yet found any reason to do that, since the fender can stay where it is as long as I remove enough screws to let it move out of the way.
Removing the sender is not a problem, although a proper plug and receptacle would be much better. I have access to the screws. I also have access to the hoses, but they are really determined to stay on the nipples. I think I should get some hose pliers.
The manual says to replace the hoses every so often. I'm 100% sure mine are original, and they show no sign at all of deterioration.
Mr Haney
L3710, ZD326S
May 23, 2022
309
81
FL
Is your lawn pretty clean? I mean is it just grass? Mine is not. After I mow, I have to undress in the garage or laundry room because I am covered with dirt the mower sent aloft. I don't mean clippings. I mean dirt.
I think your suspicion about my jack is generous, if anything. I doubt it was ever cleaned. I use a leaf blower, too.
The feeling I get from looking at the mower is that it spent nearly all of its life inside and then an heir put it outside for a few months after the owner died.
If my plan works, the grease will not trap dirt because dirt will not get to it. If not, maybe I can shoot some dry lube in there. Could be better than nothing.
Mr Haney
L3710, ZD326S
May 23, 2022
309
81
FL
My little jack modification works fine. Now the screw is only exposed when the mower is lifted, so it's not going to get dirty again. The nut pipe is sealed by threads at one end and an airtight silicone plug at the other. I think this would be a great modification for any new mower with a jack.
When I was taking the jack apart, a corroded thing fell out, and it turned out to be a thrust bearing. It was crusty but still functional, so I cleaned it up and greased it. I'm getting a new one anyway.
Unless I am missing something, it looks like Kubota did nothing to protect the handle end of the screw from abrasion. It runs through a block ("spacer") that appears to have no grease fitting or bearing, and even if it did, the block has a cylinder ("pin": K3181-18832) that goes through it, and the screw goes through a hole in the cylinder, so greasing the block wouldn't get grease between the screw and the inside of the cylinder.
