First Engine Oil Change for a Kubota L3301 HST
John Reichert
2021 Kubota L3301 Kubota AT70S Tiller
Jan 16, 2023
Crestwood KY
Hello:
I am getting ready to change the engine oil for the first time in my Kubota L3301HST. I have some experience with a compact tractor having owned a Ford 1710 for 30 years. I performed all the routine maintenance.
Is there anything unique to servicing a Kubota Tractor that I should know or that needs special attention?
Thanks for any suggestions.
John
1,418
Nothing special but just be sure you use diesel rated engine oil.
The hydraulic filters may be difficult to remove if you’re planning on replacing them get a good quality filter wrench.
Use Kubota OEM filters is also recommended.
5,066
Kubota does not make filters, so some other filter manufactuer makes them, and labels as "Kubota" OEM.
Don't know who that is, but very likely a major USA, or Japan filter manufacturer.
I use Baldwin filters, made in USA.
NorthwoodsLife
Oct 15, 2021
1,059
1,006
Wisconsin
I personally spend the extra coin and buy oil and filters directly from the Kubota dealer while it's in the warranty period.
I don't know about the 3301, but many Kubota diesels have 2 drain plugs because the pan is a W shape for front driveshaft clearance.
A nail or two or a rubber wrench will get the old filter off if you can't twist it off by hand. The new filter goes on hand tight, as tight as you can twist it on.
Remember to lube the filter's O-Ring.
Oh, and definitively make sure the old filter gasket comes off when you remove the old filter.
GBJeffOH
L4060, EA Grapple, 6' LP Brush Hog, 8' snow plow, 6' LP tiller, EA Forks, Spraye
Nov 17, 2014
237
85
Jefferson, Ohio
Hello:
John
GBJeffOH
Nov 17, 2014
237
85
Jefferson, Ohio
Hello:
John
5,270
Don’t know your model, but should be pretty straight forward if you’ve done other vehicles, equipment, etc.
I will not use any filter other than Kubota branded versions. I know they don’t make them.
For motor oil, make sure diesel rated as others said. Beyond that, use what you like.
kcs
Kubota B2650
Jan 9, 2021
148
Im getting ready to change my hydraulic / HST fluid and filter in my B2650. When I change the filter does it matter what oil I put on the gasket? As in motor oil or hydraulic oil
4,518
No but why would you use engine oil when you have a bucket of hydraulic oil sitting there?
John Reichert
Jan 16, 2023
Crestwood KY
Hello:
John
John Reichert
Jan 16, 2023
Crestwood KY
Thanks for all the advice.
FYI, I did go to a Kubota dealer for the engine oil and filter. Currently the tractor has about 45 hours on it. I have no bucket for my tractor, so hydralics are confined to the 3-point hitch. At this time, the tractor is used solely for cutting a pasture grass and weeds.
I will check the oil level in the front axle hub.
Yesterday while cutting the regeneration mode came on for the patriciate filter a part of the emission system. I was cutting at the time. This was the first time I noticed the indicator light on. It remained on for about 20 - 30 minutes. After rereading the owner's manual, as near as i can tell, that was a normal operation. Much different from my 1984 Ford 1710.
Thank Again,
John.
4,518
Thank Again,
John.
Regen on my L3901 takes roughly 10 minutes to complete. Next time make sure you increase engine speed to 2800+ RPM as soon as the lights start to flash.
5,066
Thank Again,
John.
How do you feel about leaving your Ford 1710 behind, for a Kubota?
I am considering a used (nearly new )Kubota L2301, and selling my 1100 hour Ford 1920 FEL with shuttle shift.
I am torn.
I love my relatively low hour, little 32 HP Ford (completely refurbished).
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,126
1,244
Near Lancaster, PA, USA
Welcome aboard! One very helpful item is a workshop manual. You need an owner's amnual at the minimum. That gives you the intervals for various services.
If you're doing the 50 hour serviec and want to change the hydro filter (and not the fluid) the ol' shop vac on the fill hole works well.
Donystoy
Dec 10, 2013
567
217
Binbrook, Ontario
If you're doing the 50-hour service and want to change the hydro filter (and not the fluid) the ol' shop vac on the fill hole works well.
[/QUOTE]
Just did my 50-hour service today. The one hydraulic filter was a bit of a pain and had to use a strap wrench instead of the filter wrench as a pipe was in the way. Hardly lost any oil using the shop vac. trick.
3,329
I am torn.
I love my very low hour little 32 HP Ford (completely refurbished).
Well I have never heard anyone say they had too many tractors,,, just sayin
whitetiger
Nov 20, 2011
2,923
1,385
Kansas City, KS
The HST filter on an L01 series is pressure fed, so you can remove the filter and only lose the oil in the filter.
