Mine is just a little BX1860 but I have done so much work with it that I cannot even believe how it has performed. So far, I have moved more than 68 tons of rocks in my yard and dumped them in an old drainage ditch on the back of my property. That did not happen overnight of course. That is what I moved in the last 7 years but I expect that this tractor will more double that in the coming years.
I have used this tractor to dig the holes for planting approximately 300 trees on my property. I used it to plow and til my wife's gardens and to grade my driveway. I use it to mow the whole 5 acre yard every week and to fertilize the orchard as well as spraying to control insects and pests in the orchard and gardens.
When I bought my tractor in 2013 I never envisioned using it as much as I am now. If I knew what I know now I probably would have gone with a B model instead of the BX that I have. I cannot do as much work as a larger tractor in the same time that a larger tractor can but I can still do as much work as the larger ones. It just takes more time, and since I am retired, time is not a problem. I figure if The Lord waits to call me after my work is finished on this property, I will be immortal.
I have more than 1500 hours on my tractor and it has had very few problems. The only problems that I have had were a broken fan belt, a broken front drive shaft rivet, and a few broken mower blade bolts. I have replaced the stock tires with those for a BX2360 and that give me a lot better traction and more ground clearance. I keep the maintenance up to date and the fluids changed on schedule. I am sure that is why it is still running without any major problems. It probably helps that I keep it in my insulated garage.
Taking everything into account, I am so happy that I chose a Kubota over any other brand just because of how durable and flexible it is. If there is a better brand out there, I don't care. I probably will not but another tractor anyway. The only thing that I do seem to buy is more implements for the one I have. Thankfully, the BX models are so popular that one can find pretty much anything that they want or need for these amazing machines.
