Filled tire ?
lilguy
168
12
Illinois
I have a 30 year old L2250 that has "saltwater"filled rear tires. it has started to eat away at the area around the valve of one wheel. Is it advisable to flush and refill with some other liquid?
3,102
One of two things......
take it all out - replace with tubes - place NaCl back in it - no other ballast has more weight to gallon than salt water and it is cheap - BUT it eats away at metal - thus the tube is needed!
or get it all out, repair the hole and replace with ....
washer fluid...
rv antifreeze
beet juice (rim guard)
used antifreeze
your choice - any are great ideas....some are costly some are cheap!:)
lreops
L3400DT W/ LA463 FEL and L235DT W/ BF400 Loader
Dec 26, 2011
306
Rising Sun, Maryland
"no other ballast has more weight to gallon than salt water"
I believe RimGuard (Beet Juice) is heavier, as I've been told that it weighs 10.7 lbs per gallon. Of course, not as cheap, but still not that bad as I've seen costs anywhere from $2.25 to $3.00 a gallon and you never have to worry about rust or contamination if it leaks.
Ron
3,102
Ron,
it depends on the concentration of the salt in the water.
Beet juice gets up to 11 lbs per gallon.......
NaCl gets closer to 12 lbs..... however ------- it is bad for the rims (thus the tubes) and if leaked will kill plants around the are leaked.
Beet juice is sugar and will not harm anything if leaked.....little pricey - but tubes are not needed unless you want them.
chart :
http://www.orangetractortalks.com/2009/01/comparing-types-of-liquid-tire-ballast/
