engine stops when attempting to engage blades
groggblossom
GR1600D
Jun 28, 2021
france
I start my tractor as usual but when I try to engage the cutter blade, the engine stops.
The blades seem able to rotate freely. No mention of this problem in manual.
Help, please !
2,551
This is on your GR1600D we assume?
Did this start all of sudden? OR ...... ???
Does it sound as if the engine is under load and dies? OR is this something like a switch was triggered?
Are you sitting firmly in the seat?
SDT
multiple and various
Apr 15, 2018
3,250
1,041
SE, IN
Help, please !
Engine at idle?
SDT
JerryMT
Kubota M4500, NH TD95D,Ford 4610
Jun 17, 2017
528
156
The Palouse - North Idaho
Help, please !
Increase the throttle setting a bit and see if it continues. Your idle may be too low for the power required to accelerate the blade assembly from the static position.
Tire Biter
B 2601 434 loader MMM, bunch of tractor stuff . Ford 4600
Jul 10, 2012
237
87
S.E. TN
We see this complaint so often no matter what model of machine. its obvious most of the time it’s the safety circuit. It’s open somewhere in the harness or switch.
