Kubota GF1800 front mower with a D722; 1,600 hours. Was running perfectly but I ran it out of fuel on a steep grade - fuel warning light came on, engine stalled. Added fuel, bled the lines. Fuel pressure and fuel volume are fine. Idles smooth but will not respond to the throttle. Cable and all external linkage on the pump function properly. Thinking that it is an internal problem with the injection pump. Looked in the mauals but there is very little information I can find except for R&R the the pump and set timing. Seems like it should be something simple - like me - to fix! Any advice sincerely appreciated!
