Cup Holder Advice
The_Wingnut
Grand L4060, ZD21, ZD28, ZD331, RTV X1100C, Branson 3820, JD 1020, JD 50
Dec 8, 2021
91
Tyner, NC
I have a Grand L4060 (cab type) and find the built in cup holder to be less than expected. It is so large in diameter and shallow everything I set in it falls out, such as a 16 ounce drink bottle, water bottle, tumbler etc. I will say a can drink stays put pretty good until it's less than half full. Anyone made a mod to theirs that helped? I thought about adding a different type but in this compact cab not many places to mount one.
4,699
I don't drink and drive, but why not just make a 'sleeve adapter' to fit inside the existing cup holder ?
A section of PVC or ABS might work ??
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,284
1,708
Western MT
Weathertech makes a cup holder insert. Maybe that or something similar will work, or give you ideas.
ACDII
Oct 21, 2021
678
421
Illinois
I would look for a tumbler that fits snugly in it. I have the same issue with my F350, the rubber inserts are too tight for just about anything and when you pull the bottle or can out the insert comes with it. Take the insert out and they fall all over the place when driving. I found my coffee mug, which ironically says Genuine Ford Parts, fits very nicely in the holder without the insert.
When all else fails
Velcro
Oo-v-oO
2000 B7500
Oct 31, 2021
67
55
Central NH
Not sure about your specific mounting situation, but look at a gimbal mount cup holder which can be found at marine supply places.
I need to do something similar which can also hold my cell phone. I set it on top of the heater but there's nothing to hold it in place and I almost ran over it with the back tire once when it sailed out the door opening. Whoops! probably make something that incorporates a magnet mount base and an automotive squeeze mount for the phone.
jnschnit
B2601, BH70 BH, LA435 FL, RCK60-32 MMM, BX2763 Blade, ZD1011
May 10, 2013
135
45
newark valley new york
Had similar problems with RV's. Used a piece of PVC pipe reducer from Lowes. Reduces the size of the hole and adds height. Cheap fix only a couple of bucks.
ACDII
Oct 21, 2021
678
421
Illinois
Hmm never would have thought to use stroller accessories on a tractor. My B2410 doesn't have a cup holder, so what I did was clamped one of those car door ones that clip into the window track to the ROPS. Worked OK, but was over my right shoulder. Clamping one of those stroller ones to the FEL crossbar would be ideal.
The_Wingnut
Dec 8, 2021
91
Tyner, NC
Thanks, I had not thought in that direction but sometimes the simple approach is the best
The_Wingnut
Dec 8, 2021
91
Tyner, NC
Thanks for all of the valued replies! Will be in the shop this afternoon measuring and experimenting with the suggestions.
Orange1forme
B2650 HSDC, filled tires, wheel spacers, B2728B , LA534A FEL, 3rd valve kit
Dec 1, 2018
394
57
Wa
These all look good however, my problem is exactly opposite. The existing cup holder is way to big, but I might could glue one of these in.
I understand, but those will fit in the current spot and you can use whatever size you need, smaller or bigger.
