So I'm a First-Timer and bought an old L295DT.
I am trying to do preventative maintenance (just assuming none has been done in a LONG time) and fix things as I discover them. I've changed the oil, greased, new battery, new alternator, new hydraulic pump and fluid, new fuel filter.
So I want to change the coolant. After reading, I'm thinking I should go ahead and change the thermostat and maybe hoses? Do you "pre-emptively" change the water pump? Then I read that after changing the coolant, air can get stuck and cause it to overheat. But the problem is that my temperature gauge doesn't work. So I'm thinking I should actually start with that. How do you (in simple steps and terms PLEASE) start to troubleshoot this? I'm thinking take the dash cover off and follow the wire(s).
I see several places where wires just "terminate" (were cut off at some point) and since a previous owner spray painted, there is lots of overspray on fuses, etc. too. Any guidance is appreciated. I wish I knew enough to look at a schematic and "clean up" the wiring!
