I have a L3130. Tha manual calls for changing Hydralic Oil Filter and the Transmission Oil Filter ( I have a HST ) at 50, then 200 and every 200 there after.
It calls for chaning the transmission fluid at 50, then 400 and every 400 there after.
Sounds pretty clear but when your read the directions for changing the filters, it says to first drain the fluid, then change the filters, then refill. Do you refill with the old fluid or start fresh?
I currently have 217 hours on the machine ( new to me ). I see the Hydralic filter was changed at 176 hrs ( Jan, 2018 ) the Transmission Filter was changed at 125 hrs July, 2015. I suspect the fluid was done in July 2015.
I know this is a rookie question but do both the transmission, the 3 pt hitch and the FEL work off the same hydralic oil?
Finally, would you do any service to the above at this time? Hours are good but time since last service? 11 Gallons of Kubota oil will run me $550 alone, plus filters. Not an inexpensive decision.
