Concrete by the bucketft
torch
Jun 10, 2016
2,619
869
Muskoka, Ont.
or simply replace the dead electric motor, then power it from a good inverter using the BX23s battery
Even a 1//4hp motor is going to draw 4 amps AC. Assuming an 85% inverter efficiency, that's a 50 amp draw on the tractor battery. Worse until the motor gets up to speed.
NHSleddog
B2650
Dec 19, 2019
2,149
1,831
Southern, NH
I can think of a few advantages converting the old mixer to hydraulic:
1) portability, no need for generator if you are far away from electricity.
2) dumpability, and again portability, the ability to easily carry the load and use the stick
to dump it anywhere you want. ie, there's no moving the electric mixer once its loaded.
But yes, replacing the motor would be the easy way. :geek: :geek:
LOL - I have a brand new, never used Harbor Freight electric cement mixer motor available.
2,965
Hi all, hope everyone had a great summer. I’m getting ready to pour a concrete slab to provide a level surface on which to disconnect, overwinter and easily reattach my QuickTach FEL. I stored it last winter on gravel and it sank in enough to make it practically impossible to reattach this spring-took me and 4 neighbors Standing on the bucket to tip the arms high enough to slip over the articulation cauls/locks.
My plan is a nice slab poured under an existing covered porch. Can I use the bucket as a mixing trough to easily transport and pour the mud into my forms?
Yes you can.
Please do it and report back afterwards
As others have indicated above after mixing that much concrete in your bucket, you may have to recover a bit before posting.
I do not think the diesel on the bucket will make a difference. It did not when I spread some asphalt with my bucket. Does not matter much though. If you use the tractor the bucket will self clean over time.
Tire Biter
B 2601 434 loader MMM, bunch of tractor stuff . Ford 4600
Jul 10, 2012
237
87
S.E. TN
10 x 20 ? No way I’d mix that by hand or in a little mixer. Call in a ready mix truck and be done with it.
