I just bought this tractor and the clutch has started slipping. It has 1220 hours on it. I haven't made any adjustments yet, but I also think the clutch pedal doesn't move very much compared to everything else I have driven with a clutch. I will measure the travel tomorrow, but I would guess it is only only moving 2 inches when I press it. That doesn't seem normal, but its the first Kubota I've owned. The manual I have doesn't give good details about adjusting it, it only talks about the first 10-20mm. Can I adjust it to make the slipping stop, or is the clutch bad? I will also pull the inspection cover tomorrow and check the spec on the bolts there. Thanks in advance for any help!
