So, got one of those dreaded calls from my wife
A/C is acting up in her car. Judging from her description it sounded like the compressor was going out, or it was low on freon.
So, on my way home, I pick up a can of freon with the gauges, pretty much killed $50. Hook the gauges up to her car, and everything checks out good
So then she makes the comment that her floor boards on the passenger side was wet. So, I call the mechanics shop I use, make an appointment to get the car checked.
Got to thinking about it on my way in to work with her car. Had one of those head slapper moments. The condensation drain!!!!! So, I Google the location of the drain. Apparently it's location is a better kept secret then the Clinton emails
finally start pulling off panels and find the drain. It was actually inside the car and drained through the floor board, and not through the firewall like I was expecting.
So, I clean the drain with a coat hanger. Got about a gallon of water out of it. Checked the ac and it seemed to be doing better. So...... I go to lunch. It's 100 degrees out today. Turn the ac on high, and 2 minutes down the road, the cars nice and comfy
Called the mechanic and canceled the appointment
