Chain tie downs with ratchet
mark turik
b2920
Jun 26, 2017
10
bailey nc 27807
dear folks, i want to transport my b2920 sub compact tractor safely. using 24 inch chain wratchets, how long should my chain be. 5', 8', 10'???? i just dont know whats normal and whats safest? thank you!
5,908
Your chains need to be long enough to attach to the trailer.
Too long of chains are better than too short. ;)
sdk1968
B2601HSD & CK4010HST 4WD/FEL
Oct 19, 2016
929
36
& make sure you got a a heavy enough chain for the job!
not one of those $5 walmart chains! get real load rated chain!
Utopia Texas
Kubota B2650/Kubota L6060
Jun 14, 2017
110
Brookshire & Cat Spring, Texas
For my two tractors I use the appropriate size chains but at my age find 20 foot lengths too cumbersome and not necessary so I have cut them all to 10' lengths and added grade 70 hooks to the new ends. Easy peasy and half the weight!
Rookie Farmer
B2650 SSQD forks 60" rear finish mower
Jun 9, 2017
Tenino, WA
To each there own. It is great being able to see them, but if they do come loose I don't want to be on the traffic side tightening binders up. So I prefer passenger side.
russell.still.5
197
Lafayette, Alabama
A regional company here, Tacoma Screw, sells 16'ers. Put the binders on the driver side so you can check them in your mirror.
Some states require a binder on each corner and one for each attachment (loader, backhoe, disc, etc.). I myself only use 2 binders and one on any pull type equipment hooked to the tractor.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
77
Rocky Face, Georgia
I use 10K ratchet straps myself. Chains are stronger but I never had a problem with the straps. Just have to make sure they aren't rubbing anything that will cut them.
Sammy3700
L3800HST,524Loader,BH77,Landplane,Disk,Mowers and more
Feb 20, 2012
434
41
Red Springs, NC
The length is up to you. As others stated 5/16 grade 70 is rated 5400lbs which is more than enough. You can get small ratchet binders that are rated for 5400WLL which is working load limit. You might get by with 1/4" just have to check the weight rating of chain and binder. If you look at agri supply on line they normally beat tractor supply and others prices. Also as others said check with you local dmv NC wants all 4 corners tied and a chain across any attachment.
russell.still.5
197
Lafayette, Alabama
Straps don't hold up near as good as I figured they would. I almost cut one that was over my disc on a short 8 mile trip. I now put the strap through or over a piece of fire hose where they go over an edge.
Bulldog
Mar 30, 2010
5,440
77
Rocky Face, Georgia
It depends on where they come from. I've had some that were really good and some that didn't last a month.
You should look at getting some axle straps for securing your implements. I have a couple sets from Northern tool that I've been using for over 10 years. I hauled my v-rake almost 200 miles when I bought it and didn't have any problem with them.
mckenzie913
12
Tennessee
I plan on using axle straps and ratchet straps with my L2501.
Creature Meadow
Sep 19, 2016
1,063
135
Central North Carolina
For my L4600 I use chain and binder for front of tractor same for rear and ratchet straps across loader and any implement I have on tractor.
This setup works nice for me, many ways to do it but this is my preference.
ArkansasTed
2017 Kubota L3301 HST, LA525 FEL, 6' Land Pride box blade
Aug 5, 2017
Eureka Springs, AR
I bought two 3/8" x 14' chains for $19.99 each at Harbor Freight a couple of weeks ago. They were on sale...regular $39.99. Included 3/8" hooks on both ends.
badcompany
Georgia
I use a huge chain in the rear, then move tractor fwd a bit on trailer to tighten it up, then a heavy duty ratchet strap up front.
NEPA Guy
B2650HSDC, Spacers, FEL, BH, Snowblower, Snowplow, PBar, Forks
Nov 28, 2015
424
Pennsyltucky
I just bought a package to chain my 2650 for transport. What would happen if you were in an accident? You or someone else could get hurt, or even worse, you might damage your tractor. :D
