BX25 brakes
Flienlow
Kubota BX25D, Kubota U25 mini EX, SVL75,Landpride Grapple,Landpride grading scra
Mar 9, 2015
352
snohomish
I have noticed that my brake pedal is going all the way down now. I am not sure if this is an adjustment issue or if the brakes need to be replaced on this tractor. Google has given limited search results on the subject. What should I look at first?
Thanks.
6,403
Something ain't right!
HST's rarely use brakes.
And wet brakes normally outlast the units they are in.
Did it get run with the parking brake set?
Flienlow
Mar 9, 2015
352
snohomish
There is always that chance! :D but I dont think that is my issue.
Flat6s
BX 25 D
Jun 14, 2018
Burlington Indiana
Brake pedal can be adjusted easily. Procedure is in owners manual. Follow pedal linkage. It will cross over to opposite side of tractor. The turn buckle adjust the pedal. Your brakes will be like new after adjustment
