My new BX2360 may have a problem. When I set the PTO clutch lever to "off" it moves the PTO shift lever from the "rear PTO only" position to half way between the "rear only" and "both middle and rear". This movement also takes the PTO out of the "rear only" mode and can cause a little grinding noise if I try to put the clutch lever all of the way to "off". Is this normal? I called my dealer, but he does not have a BX2360 in stock at the moment to check. I have 9.5 hours on the tractor and I don't remember these levers interacting the last time I used it. Nothing seems to be bent, but there is an adjustment to the angle of the shift lever that may have changed.
