xrocketengineer
Hi everybody from rainy and swampy Florida. I have a BX1880 that I bought new last year with a 48 in. belly mower and FEL/grapple. It came with R1 tires that worked sort of OK during our "dry season" for mowing and also for other chores like hauling out cut down trees and limbs. But the rains came in around May and they are still here. The soil gets so soft that that the front tires sink in all the low spots around the yard and create incredible ruts. Forget about using the FEL there. In the other areas, what has happened is that the tire lugs appear to put so much pressure on the soil, that not only that creates indentation as you mow but also the mower cuts lower as the tractor settles and has messed up the grass.
So, my conclusion is that the tires are too small and the R1 pattern is way to aggressive for my use. I have just bought a set of "all terrain tires" with wheels from The Mowers Parts Group for the BX2380/Bx2680. I have not tried them yet, I do not expect miracles but I hope that my lawn will improve eventually.
To not make the story drag on much longer, the bottom line is that the bigger tires will fit perfectly the BX1880 with the 48 in. deck with no modifications or adjustments needed with almost an inch of clearance to the closest point being the left rear anti scalp roller on the deck with it all the way up.
Now, these tires have a rounded shoulder unlike the R1's and R4's. I would assume that the roller would be a lot closer to the tire shoulder with those.
What I also believe is that since the frame and mechanicals are the same on the BX1880 as the BX2380/BX2680, is that the 48 inch mower would fit those models too with the possible R1/R4 tire clearance limitations on the deck roller.
I hope this helps to shed some light on the tire upgrade path for the BX1880.
