I've done quite a bit of searching on this issue and found a few threads but nothing with the answer to the question I'm going to ask.
The question. Does anyone know the "proper value" of the signal sent from the alternator to the instrument panel for the tach/hours. I tested as per the WSM and at idle I get ~.482v and that increases as the engine speed increases. I've dug through the manual and have not found the "proper value".
So a bit more info. While mowing last week I noticed the tach/hour stopped registering. Tach does the sweep when powered up. Yesterday when going up a steep hill the engine sputtered and died. Then realized the fuel pump wasn't running. Pulled the mower off and found a wire (red/yellow) going to the fuel pump was broken. Repaired that and the pump is now working again but still no tach/hour. After testing for the "proper value" I ran a jumper wire from the output terminal of the alternator to the input of the of the instrument panel,,,, still no tach/hour. Would really like to nail this down before spending big bucks on a replacement panel.
