This might sound silly--but I ask anyway. Let us say you need to replace the fan on the little machine, the one almost impossible to get to. Or maybe the seal is leaking a little and you simply want to replace it on the inboard side of the transmission.
This is the question I have pondered all day.
What if we cut the drive shaft in half, well maybe not exactly half, just in two pieces. Removing the bolts from the motor end of the shaft it seems as though the front portion would simply fall straight out, leaving the rear section coupled to the transmission. If one can then reach the bolt in the rear coupling, just in front of the fan--obviously we cranked the shaft over so the bolt is facing down--it seems the rear portion of the now cut drive shaft should be removable by sliding it rearward.
Since I have never done this, nor removed a drive shaft at all, is this possible in the opinion of those who have.
Continuing and assuming that cutting the shaft in half will allow its removal to begin with, we turn to repairing the shaft. My thinking lead me to two ideas. First. Search part houses for a small universal joint that could be incorporated into the cut shaft so it can be made whole. Second. Turn the cut ends of the shaft and weld plates to each end, attached with bolts--thus making the shaft whole.
If this process is feasible it certainly would be less expensive that having to pay to have the transmission completely removed just to service a broken plastic fan or new oil seal.
What do you think...
Eric
ibgolfr@gmail.com
Eric
ibgolfr@gmail.com
