BX1500 Won't Shut Off
wardsfarmnj
2016 L3901 FEL 2004 BX1500 FEL 71" Tiller 37" Tiller 71" Finish Mower Flail Mow
Jul 8, 2015
49
Mannington Twp. NJ
After doing search I'm thinking its most likely the ignition switch, since I can literally turn the key to off and pull the key out and the motor will not shut down. However it does seem to shutdown after a few minutes. Could this indicate something else?
Also at least one thread I read said that if I push the fuel shut off solenoid I can get the motor to turn off. What exactly am I pushing on the solenoid to do this?
I won't be able to get a switch till tomm, but need the tractor to unload the tiller I have coming today.
Thanks for the help in advance
Grouse Feathers
Feb 16, 2015
1,022
Lovells, Mi
I would check the OPC systems. If the OPC shuts down your tractor, the ignition switch is probably the problem. If the OPC doesn't stop the engine then it may be the solenoid.
wardsfarmnj
Jul 8, 2015
49
Mannington Twp. NJ
Replaced both the fuel shut off solenoid and ignition switch but it still does not shut off...The OPC does not work, but it actually hasn't since I got it I do not think...Approx 2-3 weeks...I'm assuming maybe fuel shut off is not getting a signal but not sure where to start for that.
Grouse Feathers
Feb 16, 2015
1,022
Lovells, Mi
In the WSM for BXxx60s the electrical Troubleshooting section lists two reasons for the engine not stopping when the key is turned off:
1. A 15 amp fuse is blown
2. The wiring harness is disconnected or improperly connected between the ignition switch and the solenoid
I have a BX2370 and my wiring is almost identical to the BXxx60s but I have no idea about a BX1500. The fuses and wiring should be a good place to look next.
coachgeo
Nov 16, 2012
2,460
32
Southern OH
Figured it out. Thank you
????? Don't just leave us hanging...:confused:.... for future readers whom may come across this issue; What was the problem and how did you fix it?
wardsfarmnj
Jul 8, 2015
49
Mannington Twp. NJ
Sorry was tired after spending fixing it, seems it was the actual wire to the solenoid, it was worn through. It looks like it came out of the protector so it must've rubbed on something.
