BX 2670 3 Point Issue
DFish
BX2670
Apr 23, 2019
Sherrard, IL
Hi All, This is my first post. I have a 2015 BX2670 with 135 hours that I bought new and my 3 point stopped working on Sunday. I mostly just mowed and back bladed with it the first 2 years, then I bought a used FEL and a grapple last fall. I had been using my grapple and box blade all weekend with no issues. I needed to mow so I removed the FEL and box blade and slid the MMM under the tractor to hook it up. I lowered the 3 point to connect the pins and needed to raise it a little to position the deck and it wouldn't go up. I checked the linkages, fluid level, flow control and see nothing wrong.
I was hoping to get a few things to check before I take it to the dealer.
Thanks in advance.
ipz2222
L235, bx2670
May 30, 2009
1,927
32
38
chickamauga ga usa
Just inside lft rear tire at the back is where the mmm linkage hooks up to the 3ph linkage. Someone else had the same issue and the linkage had come off there.
DFish
BX2670
Apr 23, 2019
Sherrard, IL
Thanks, I checked the linkage, it is attached. I was hoping it was something simple like that but it appears I will not be that lucky.
1,418
Is the feedback linkage still attached and somewhat adjusted? Does it even have that linkage?
6,405
Thanks in advance.
How many lines did you disconnect to remove the FEL?
